HP Analyzer 4156b - Flex command
Hi together
I am very new to Labview therefore I have lots of questions Smiley Wink
Does anybody have an example of how to use the flex command in a Labview VI? I already have the Programmers Guide of HP but a working example would help me to program my own VI.
Thanks 🙂
(3,936 Views)
Accepted by topic author twodays
First of all, identify what type of communication you have wih your device. i.e. GPIB, USB, Serial etc.
If GPIB is the right way, you may then use the measurement & automation explorer to find the GPIB address (if you don't know).
Then, go to "Find Examples" in Labview and see the GPIB communication examples that LabView has builtin. This will help you send commands and recieve replies from the instrument. If more detailed controll is required, you might endup creating a more advanced VI that can set the instrument with the parameters you define, then read the results.
Another way around this is to find the LabView instrument drivers where most of the time, it contains an example of sorts for device communication.
(3,920 Views)
Hi
A driver exists in the NI instrument driver network
It is not written in LabVIEW but calls a dll that does the work.
The only problem is you can't change it but you can add commands that use visa if necessary
greetings from the Netherlands
(3,915 Views)
Hi zerotolerance and Albert.Geven
Yes, it is a GPIB communication.
Thank you for your reply. With that those clues I am able to begin 🙂
(3,899 Views)
