HMR3500 Magnetic Compass Module
1-another problem that i am facing is i am unable to compensate/isolate/deviate the HMR-3500.
2-when the value of azimuth is between 270 and 290 it gives us two values either 270 or 25.
kindly guide me through it.
regards
USMAN
(3,103 Views)
 Hi Usman,
I assume this is in relation to another forum post. Normally we try to keep one issue per thread in case other customers encounter similar issues.
As far as your specific questions, they sound very specific to the HMR device rather than interfacing with the NI hardware in your system. It might be best moving forward to follow up with the HMR manufacturer to see what the values you are getting indicate.
Best,
Chris D. | Applications Engineer | National Instruments
(3,072 Views)
