HELP! ilrd() problem in VB
I'm having trouble in VisualBasic with an HP DMM using the GPIB cmd :
ilrd(Dev%,ValueStr$,Len(ValueStr$)).
I'm pretty sure it's how I've dimensioned ValueStr$. What is the
proper way?
I've also seen the call used like:
ilrd(Dev%,ValueStr,Len(ValueStr)). No $ signs. Whats the difference?
my code uses:
Dim ValueStr As String
Dim Dev As integer
Also, what does the $ at the end of ValueStr mean, and the % on Dev?
(5,740 Views)
Check out the VB examples that ship with our driver.  These are usually located in C:\Program Files\National Instruments\NI-488.2\Languages\Visual Basic
Scott B.
GPIB Software
(5,732 Views)
In answer to the second question:
"Also, what does the $ at the end of ValueStr mean, and the % on Dev?"
The $ is the identifer for a string variable and % is the identifier for an integer variable.
Hope this helps clear it up.
(5,724 Views)
You must allocate enough buffer for the string variable before ILRD() or IBRD() call.  Just declaring a string variable with Dim ValueStr As String does not allocate any buffer and its default length is zero.
ValueStr = SPACE(256)
status = ilrd(Dev,ValueStr,Len(ValueStr))
% specifies Integer type and $ specifies String type.  This style has been kept unchanged since GW-BASIC era.
Dim X As Integer and Dim X% are the same for declaring an Integer, however Dim X declares Variant type.
(5,722 Views)
On Fri, 17 Mar 2006 11:41:48 -0600 (CST), Makoto <x@no.email> wrote:
>You must allocate enough buffer for the string variable before ILRD() or IBRD() call.&nbsp; Just declaring a string variable with Dim ValueStr As String does not allocate any buffer and its default length is zero.
>&nbsp;
>&nbsp;
>% specifies Integer type and $ specifies String type.&nbsp; This style has been kept unchanged since GW-BASIC era.&nbsp;
>&nbsp;
>Dim&nbsp;X As Integer and Dim X% are the same for declaring an Integer, however Dim&nbsp;X declares Variant type.
>&nbsp;
Thanks, this is what I needed:
Const ARRAYSIZE = 1024
Dim ValueStr As String * ARRAYSIZE
and I found out that Dim Count% is the same as Dim Count As Integer,
$, string...
(5,711 Views)
On Fri, 17 Mar 2006 09:41:44 -0600 (CST), ScottieB <x@no.email> wrote:
>Check out the VB examples that ship with our driver.&nbsp; These are usually located in C:\Program Files\National Instruments\NI-488.2\Languages\Visual Basic
>&nbsp;
>Scott B.GPIB Software
Thanks, that just what I did and foun the problem!!!
(5,711 Views)
