08-25-2006 03:08 PM
08-25-2006 04:55 PM
08-28-2006 12:14 PM
08-28-2006 01:42 PM
It turns out I had the GPIB address set on the instrument wrong. (I was trying to write to device 1 and I had the device mistakenly setup as device 11.)
So now I can see the device (a yokogawa power meter) but I still can't write/read to it. I get an error from the instrument that I'm sending the wrong command. The odd thing is I'm sending the same commands that I was when using a NI PCI-GPIB card. I think there must be a different defalt setting in the NI 488 config. properties.
04-08-2022 01:57 PM
Hi Paul,
I know this is an old thread, but did you ever figure this out? I'm having the same dilemma, so I'm unsure if I should extend the GPIB side or the USB side. Thanks.
04-11-2022 11:24 AM
A USB extension cable should be fine, as long as it is a quality-made USB 2.0 cable which doesn't cause the overall cable length to exceed the 5m specified in the USB specification.
Low-cost or old cables might not work well at that maximum distance. Powered extenders are available, but my personal experience with these has been poor. The ones I have seen place the "powered unit" at one end of the cable, which still requires exceeding the standard in one direction. If you need to go beyond the allowable length I would recommend a powered USB hub, unless you have a powered extender you know to be reliable.
