GPIB using C++
I want to communicate with an old optical spectrum analyzer HP71450 using C++ in order to learn and make it work faster.
I have a LabView interface for it and I controll it using USB-GPIB cable.
I read some sample program I found on the internet and I understand I need ni4882.h , and maybe other header files that replace "decl-32.h".
could someone help me started with this project?
first, I'm using windows7 on 64 bit computer - is the above file still suitable? if so, where can I found it? it not in any directory under document\national instrument.
can someone direct me to simple read-write file using GPIB?
thanks
(6,777 Views)
(6,775 Views)
If you have a. LabVIEW program, switching to c++ will not make anything run faster. Bad programming or instrument limitations need to be addressed.
(6,765 Views)
