GPIB timeout only when using multiple devices
I have a system using multiple GPIB device (about 5) all connected to the same slot. If I use any of them alone, I have no problem.
The problem occurs when one of the instrument is performing a task that can take some time (1 to 15 seconds). The two of the other instrument are giving me a timeout error. These instrument are Newport ESP300 and PI E-710, both are stages controller.
I read every instrument in its own loop running in parallel.
Anybody with an idea?
Thanks in advance!
(3,605 Views)
GPIB is not designed for parallel operation. What kind of mechanism do you have (if any) to ensure that there is only a single talker at a time?
(3,602 Views)
Well I don't have any... So this is probably the problem...Smiley Sad
I tough it would be a better design to have 5 states machines, one for each instrument rather than I big one... Anything to suggest to fix that quickly?? Semaphore maybe?
Thanks for your quick help...
(3,598 Views)
