08-18-2006 10:42 PM
08-22-2006 03:22 PM
08-22-2006 08:32 PM
Thank you for your help Robert,
I am running:
NI-VISA (3.4), NI-488.2 (2.43), Trad NI-DAQ (1.0.2), NI-PAL (1.10.0f0), NI-Spy (2.3.0.49152), NI-MAX (4.0.0.3010), and the labview runtimes for 7.1 and 8.0 on both machines. The only different software is CVI RT (7.1.1.350 on the "working" machine and 7.1.0.307 on the failing machine.)
The failing computer has 2 network cards in it...I have updated the drivers both, and switched to the other card...but the GPIB still failed. I have not tried pinging the GPIB after it fails - but closing the software and reopening it (skipping the WT init) will allow them to resume operation for a bit.
The connection is through a network which has a small hub which connects to a few MX100's, a few OPTO-22 controllers for input/output, and the single GPIB-ENET/100. I have not used the same network cable on both computers though.
Attached are 3 spy files, the one is from when the unit fails and the other 2 are "normal" operation from both computers.
Do you think that if I attached directly to the GPIB (bypassing all network) i will get a response to the "*IDN?" query? When both computers connect through the hub to the GPIB, neither gets a response to that query (EABO error). Also, do you think that EOI/EOS settings could be causing some problems?
Thanks again,
Tyler
08-23-2006 02:38 PM
08-25-2006 01:01 AM
I fixed the problem mentioned above where the GPIB was trying to communicate with non-existant devices...now when I run NI Spy, I get no errors.
I also replaced the RAM in the machine (as I have read that may cause the EDVR error) and upgraded it to 1gb where it was only 512mb before. I switched DIMM slots for the memory as well. I replaced the hub on the network and put new ends on the cable for the computer as well as the cable to the GPIB.
Just now, I installed an evaluation version of labview 8 on the computer and ran my exe. I still get the EDVR error. It appears to be random as it occured this last time around 15 minutes after turning on the program; other times it will be up to 2 hours. Not only the sporadic nature of problem, but also the fact that it does not seem to affect the 3 MX100's nor the 2 Opto22 brains on the same network.
Is it possible that there is a hardware problem with the GPIB or possibly the WT230's that would be causing this? According to the manual, the WT230's should accept the *IDN? command, but they do not.
Tyler
08-25-2006 07:01 AM
