GPIB control Visual Basic 6 comunication error
Hi, I´m trying to communicate with my device by doing a VB 6 program.
I've added the .bas files needed, and instaled the drivers for device.
When I run Measurement  & Automation application I can find my device, and I can send messages to it, using Interactive control.
Ok, I took the example in VB (simple.zip) to try to comunicate the first time with the device, changing to the correct addresses, but I always get the following error when I send "ilclr %Dev" :
                              Unable to clear device
                              ibsta = &H8100
                              iberr = 4 <EARG>
The question is: How to know if I'm really comunicating with my device?? or What I'm doing wrong?
Thank you
(3,506 Views)
Hi Calimeru,
First of all, are you sure the reference "%Dev" is correct for your device? is this the alias name of your device in max?
To know if you are communicating with your device, you can send usual commands as *idn? to see if your device answer your request.
Then, could you try using this example : http://zone.ni.com/devzone/cda/epd/p/id/2258
Let me know,
Olivier L. | Certified LabVIEW Developer
(3,468 Views)
