GPIB address input format for Agilent Instrument Drivers?
Hello all,
I am trying to use an Agilent instrument driver for a E1326B VXI multimeter. I know that I can communicate with it using the standard VISA calls, but when I try to use the driver, nothing seems to happen. I know the address for the device is GPIB0::9::3::INSTR but this doesn't seem to be accepted properly in the instrument driver. Any hints or clues?
Thanks.
(3,971 Views)
From the way you describe it, you've got it connected through a GPIB-VXI controller. And based on the address, I'd say you've got an Agilent controller, probably a 1306/1406. Therefore, you need to use your configuration utility to create a GPIB-VXI and use the GPIB-VXI syntax. Based on its secondary address, your device is probably at LA 24. Therefore, it would be something like:
"GPIB-VXI0::24::INSTR"
Dan Mondrik
Senior Software Engineer, NI-VISA
(3,971 Views)
