10-20-2005 02:34 AM
10-20-2005 10:02 AM
10-20-2005 10:24 AM
10-20-2005 12:50 PM
10-21-2005 02:17 AM
Thank you for your comments.
I will describe a littel bit more of my environment: the GPIB-USB-HS is connected to an 16 channel temperature measuring instrument "microlink TC16", build about 1987. So when I write a command I switch a channel with a parameter for the amplifying, then the GPIB device begins continously to talk 2 Bytes data. When I increase the read buffer (e.g. 4Bytes) I get no result, maybe the GPIB device do not understand the read request.
If there is no may to read more then 2 Bytes with one read, what can i do?
M.Tiedje
