GPIB-USB and Matlab
What GPIB device are you using? Can you communicate with the GPIB device in Measurement & Automation Explorer? You need the NI-488.2 driver for NI GPIB devices.
Thank you,
Simran K
Message 11 of 51
(9,887 Views)
Hello!
I´m using a national instrument gpib-usb, i have the driver installed, and I can communicate with my instrument but I cannot guard information. I need to guard information in the memory of my instrument (osa) and after to read them for plot them in matlab or to guard them directament in matlab, you know how I must do it?
BYE
Thank you for answer my questions! Thank You
Message 12 of 51
(9,874 Views)
Thanks for letting me know that everything works in Measurement & Automation Explorer. Check the programming manual for your instrument to see how you can guard information in memory. Also, you might want to contact Mathworks at support@mathworks.com for help programming in Matlab.
Thank you,
Simran K
Message 13 of 51
(9,855 Views)
I have the GPIB-USB-HS (NI )driver installed on my 32 bit Linux box. I'm trying to communicate with a spectrum analyzer, and my linux box recognizes the device, but I cannot access the device through Matlab. I keep getting the error "The Specified Adaptor could not be found".
I'm looking for a dll or .mdd file that will allow me to use my Agilent 8753ES in Matlab, through linux. Anybody know where I can find these?
Message 14 of 51
(9,792 Views)
Hey,
Check out this thread, it has some information that might help you in your application.
Thank you
Message 15 of 51
(9,758 Views)
I am trying to connect an HP 4195A Network/Spectrum analyzer to Matlab using the NI GPIB-USB-HS interface. I have downloaded NI-488.2 driver and am able to successfully communicate with the instrument. However, I am unable to communicate with the instrument using matlab. When I enter
>> instrhwinfo('gpib', 'ni');
I get the following error
??? Error using ==> instrhwinfo at 234
Specified ADAPTOR was not found or could not be loaded.
Where can I download this adaptor? It seems like I need a National Instruments driver for matlab (.mdd file) , but I can't seem to locate one. I'd greatly appreciate it if someone could point me towards one. I know this is very similar to another question, but the response simply points back to the same thread and does not address the question.
Message 16 of 51
(8,407 Views)
Sorry for digging up an old post but I can't figure out how to make a new thread...
I am trying to control the Agilent 89090A via GPIB-USB-HS using MatLab ...
I am trying to help my University save $50,000 of hardware upgrade! I am trying to communicate with this device (Agilent 89090A)  and I have a little success so far. I just need to know how to send commands to it via MatLab.
This is what I have so far:
s = gpib('ni', 0, 0)
fopen(s)
fprintf(s,'on')
out = fscanf(s)
input('Press Enter to Continue')
I am able to sucessfully communicate with the GPIB device and turned on its port.
When I do
instrhwinfo(s)
I get:
>>  instrhwinfo(s)
ans =
             AdaptorDllName: [1x87 char]
          AdaptorDllVersion: 'Version 3.0.0'
                AdaptorName: 'NI'
              VendorDllName: 'gpib-32.dll'
    VendorDriverDescription: 'NI-488'
But when I try to turn on Remote Control for the Agilent device I get an error:
Error using icinterface/fprintf (line 147)
GPIB: NI: GPIB board is not Controller-In-Charge and is not properly addressing
itself.
Error in Test2 (line 3)
fprintf(s,'on')
Is that the wrong command or what?
This is the manual for the Agilent device:
http://www.chem.agilent.com/Library/usermanuals/Public/89090-90003_ebook.pdf
REM – Remote
Parameter
[ on | off ]
Reply
[ on | off ] <CR> <LF and EOI>
Description
This instruction is used to switch remote mode on and off. With REM ON the
temperature control unit is set in a remote mode. In this remote state the
keyboard is disabled for all inputs (only the UP , DOWN , and CLEAR  keys are
accepted). The ENTER  key is only accepted within the remote function context,
that is to change the display for system and main functions and to reset
remote to off. However, the function REMOTE ON, which is selected, can be used
to reset to REMOTE OFF instead of using the REM OFF command, (see also
“Remote Mode” on page 88).
Reply Description
The REM instruction without parameters returns a string which represents the
current state of the temperature control unit:
on = remote mode
off = normal mode
See “CSM – Agilent ChemStation Mode” on page 98 for interpreting the reply
when using the CSM command.
Any help would be greatly appreciated!
Message 17 of 51
(8,238 Views)
Here are some info on the USB device:
Message 18 of 51
(8,236 Views)
Hey Tnguyen628,
          Since you're able to communicate with the device using certain commands, we know that the NI GPIB-USB Controller is working properly. When it comes to specifying commands in MATLAB, you may find this information helpful. You may also want to consider contacting Mathworks at support@mathworks.com for help programming in MATLAB. Hope this helps!
--Ryan S.
Message 19 of 51
(8,216 Views)
Hi there,
Thanks for the reply.
When I try communicating with the device via NI's Measurement and Automation I get this error:
iberr = EABO
EABO indicates that an I/O operation has been canceled, usually due to a timeout condition after a GPIB read.  Before reading from the instrument, verify that the GPIB command you are sending is understood by your device and instructs it to place data in its output buffer.  For information on your device's command syntax, consult the instrument manufacturer's user documentation.
How do I get around it? here are some screenshots - Again the Device that I'm trying to connect to is the Agilent 89090A
Message 20 of 51
(8,210 Views)
