GPIB-USB-HS
I have two identical interfaces , one of them works properly while the other, as soon as it is connected to the PC ,it turns on the active led (green)
but,after a couple of seconds the ready led glows amber and both the lights switch off.
After that,windows device manager shows it in wrong state , MAX does not recognize it.
It generates a 441 event ID with the following   event data
  EventData
    DeviceInstanceId USB\VID_3923&PID_709B\01886823
    LastDeviceInstanceId USB\VID_148F&PID_2573\5&165678ce&2&8
    ClassGuid {4D36E972-E325-11CE-BFC1-08002BE10318}
    LocationPath PCIROOT(0)#PCI(1D07)#USBROOT(0)#USB(8)
    MigrationRank 0xf000ffffe0000033
    Present false
    Status 0xc0000719
Any suggestion ?
Thank you in advance
(3,413 Views)
sorry for the late reply.
I think you should contact your local NI branch office and open a service request to further troubleshoot the problem and eventually send the device to repair.
Bye
Licia
(3,322 Views)
