GPIB-USB-HS problem
Hi. I was using a Window XP SP3 and a GPIB-USB-HS it was working correctly.
But virus may have damaged the software. I tried to reinstall to the driver but I am encountering the same problem over and over again.
On the 'Device Manager' the GPIB-USB-HS shows up that it was installed properly but on the 'Measurement and Automation' window doesn't.
I'm using a Keithley 2002 Multimeter and Wayne Kerr 4300 LCR Meter.
Thank you in advance.
(3,268 Views)
I would try resetting the MAX database.  This will clear all of your PXI settings, so you might want to do an export first.  But the reset is somewhere in the Tool menu.
(3,235 Views)
