04-21-2011 02:56 AM
I have a problem with GPIB-USB-HS on my system. When I ran the application created by myself, I often lost connection to devices. Active LED was blinking to try to communicate to devices but sometimes I lost them but it was not always. Sometimes it works fine. Does anyone have the same or similar experiences with your GPIB-USB-HS?
04-22-2011 08:40 AM
04-24-2011 05:44 PM
I only have one USB device as GPIB-USB-HS but I have 14 GPIB devices connected to it.
I tried to shorten total length of GPIB cable connection but no luck, so I don't think it is power issue.
Because if I had 4-5 devices connected, the same thing happened before when I used the same GPIB-USB-HS.
I will get another one and try it. It is also suspected to have bad cables. I will keep on investigating.
04-25-2011 01:01 PM
Yeah, I have had problems with only 3 devices on it, normally when I parallelize the connection setup. I can get it to work if I serialize the connections. Even the order can matter in a serial setup. Put your most problematic instruments closer to the source. But even with serial connection setup, you will eventually run into a length limit. Not sure if the GPIB-USB-HS can draw enough power to drive a large complex network. You might be better off running your setup with an internal PCI card which might be able to draw more power off the PCI bus.
