GPIB-USB_HS+ driver
I have a GPIB to USB adapter and need an older version of the driver  (McPherson Equipment says version 14)  I cannot operate a McPherson equipment with out it and it must be version 14.   I have tryed to find this driver b ut I can only go back to version 17
I just need the driver
thanks
Don Fronek
(1,611 Views)
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019QOfSAM&l=en-US
NI has identified non-genuine NI-branded GPIB devices sold through third-party online vendors and is committed to your safety and the integrity of your measurements. Beginning with version 17.6, the NI-488.2 driver supports the ability to recognize counterfeit GPIB devices. NI has intentionally removed NI-488.2 driver versions 1.0 through 17.0 from NI Downloads to enable you to quickly identify non-genuine devices so that you do not risk harm to yourself and others, can trust the quality of data in your applications, and are able to return the non-genuine devices and plan accordingly to your timelines.
NI is aware that not all applications can be upgraded to the latest version of the NI-488.2 driver. Please reach out to NI Support if you need access to an older version of the driver.
(1,502 Views)
Workaround - download NI Device Drivers Feb 2015 - this contains 488.2 v14.0, I don't know if you can install this individually if not worst case, install all the drivers.
https://www.ni.com/en-us/support/downloads/drivers/download.ni-device-drivers.html#327634
You can take this approach if you could not get NI support to share old version.
Santhosh
Soliton Technologies
(1,494 Views)
