GPIB-USB-HS does not work
Hello !
I just bought a GPIB-USB-HS but it doesn't work. I have all the drivers needed on my computer but i can't use this gpib-usb connecter because my computer can't find it.
When I open NI-MAX, I can't even try to find a GPIB device. My computer detects nothing when the device is put in the computer...
Do you have a solution to my problem ?
Is it simply that the GPIB-USB-HS is broken and will never work ?
Thanks for your answers !
Message 1 of 13
(6,772 Views)
Did you buy it from NI ?
Could be counterfeit.
Message 2 of 13
(6,752 Views)
I didn't buy it directly from NI, I bought it  by a broker in a package. So it is not counterfeit.
The device is new, that's why I don't understand why nothing works...
Message 3 of 13
(6,740 Views)
Hello Samea,
Do you have a message "USB device not recognized" when you plug it ?
If yes, this link could help you:
http://ae.natinst.com/public.nsf/web/searchinternal/12619aaeda596b5f862576cd00742c44?OpenDocument
Else, this tutorial could also help you debugging:
https://www.ni.com/getting-started/set-up-hardware/instrument-control/gpib-connect
Have a nice day,
Armando
Message 4 of 13
(6,716 Views)
Hello Armando,
Thank you for your answer.
My computer does not understand that a device is connected so I have not a message about a USB device.
And when I open NI MAX and I go on "Devices & Interfaces", I cannot try to scan for instruments.
Here is a screen capture of NI MAX when I open it.
Do you have any other idea ? Maybe it is because something is broken in the device, but it is a new one.
Have a nice day,
Samea
Message 5 of 13
(6,713 Views)
The problem is that you bought this device from a distributor and not directly from NI...
What do you get when you go to Tools»NI-VISA»VISA Interactive Control?
Do you see anything like this or nothing at all?
Message 6 of 13
(6,711 Views)
When I go to the VISA Interactive Control tool, I can't find any device.
Moreover, the two LEDs "Ready" and "Active" on the GPIB device are off.
Message 7 of 13
(6,709 Views)
What is the serial number on the label of the unit? I can log into my account and enter under my devices and I'll see if it is recognized.
The last time I did this for someone with the same issue it came back as an invalid device.
Or you can try this also.
-AK2DM
Message 8 of 13
(6,694 Views)
The device is :
Model : GPIB-USB-HS
PART NO : 187965G-01L
SERIAL NO : 16A5DCC
Thanks for your support
Message 9 of 13
(6,691 Views)
I tried to register S/N 16A5DCC under my products and it was unable to Validate it, not a good sign.
I would contact the vendor you purchased it from.
-AK2DM
Message 10 of 13
(6,680 Views)
