GPIB-ENET100 ibln function on Linux.
I use the function ibln in my application. But this
function seem to not work correctly. The variable listen is always egal to 386 even if a listen instrument is connected or not.
This function is realy implemented in the GPIB-ENET100 driver on Linux ?
(3,368 Views)
Can you try this test again in ibic and see what values it returns?
I have not experienced any trouble with this function before. Also what version of the driver are you using?
Best Regards,
Aaron K.
Application Engineer
(3,368 Views)
