GPIB-ENET/1000 and 100 compatibility
I will be using a GPIB-ENET/1000 controller to perform remote control and monitoring of some test equipment. Long lead times and our archaic purchasing procedure mean that I won't get the controller anytime soon; however, I do have some older GPIB-ENET/100 units available.
Speed is not a concern so I believe in that regard the 100 should be more than adequate for my needs, but my question is when I receive the 1000, will any code I design using the 100 work with the 1000?
(1,655 Views)
Hello, rcrummett208
It depends on what references do you use to your device in your program. You can try simply changing that references to your new device and I think it should work.
Regards
(1,548 Views)
