02-01-2006 10:15 AM
OK... I think the error I am getting is 78 on the ENET/100 box. Any ideas what this means?
Cody
02-02-2006 10:22 AM
Try upgrading to the latest firmware revision (C.9) on the ENET/100 and see if this prevents the error.
Scott B.
GPIB Software
02-02-2006 12:54 PM
02-03-2006 12:56 PM
05-08-2006 08:17 AM
LabVIEW, C'est LabVIEW
05-09-2006 03:22 PM
Relaunching the application should not be necessary, so to troubleshoot it, please post an NI-Spy capture using the methods described in this KnowledgeBase. Also, the version of NI-488.2 and NI-VISA you have installed will also be helpful.
Have a great day!
Chris R.
05-09-2006 04:32 PM
05-11-2006 11:30 AM
05-12-2006 05:30 PM
Hi JohnPierre,
I will take a look into this spy file and let you know if I have any suggestions.
Chris R.
05-17-2006 11:17 AM
Hi JohnPierre
It appears in the SPY file that you are trying to viOpen ("RPM4" ) which I assume is your VISA alias. This is done several times and it never returns. Is this you trying to open the GPIB-ENET/100 in VISA? Also, IBFIND fails, which may be the troubleshooting wizard. This shouldn't happen, since it should at least return EDVR (driver error), even if the network is down and you can't get to the ENET/100. I recommend reinstalling the NI-488.2 driver or trying the same procedure from another fresh computer to see if you get the same results there too. The NI-drivers on your computer seem to be confused. A reinstallation of drivers may fix this problem. If possible, try this and report back to see if that helped.
Have a great day!
Chris R.
