GPIB EBUS Error Code 14
Am using NI-488.2 on VC++, while i'm trying to communicate with the Instument it throws EBUS (14) Error.
The Command which i have used is
ibln()
What may be the cause, please let me know as soon as possible with the solution.
Siva.
(4,014 Views)
Hi Siva,
Are you able to communicate with your device using Measurement and Automation Explorer (MAX)? I would suggest trying that first, as it is possible that your device is not connected properly... See this link for some additional information on the error. Hope this helps. Thanks!
Ebele O.
(3,994 Views)
