FPGA-RT error 25
Hi!
I'm getting the error message 'Error 25' when I try to read data to RT from the FPGA. It has worked earlier, but then decided to stop working. Weird to notice is that I seem to be able to establish a contact to the FPGA, since the 'Open FPGA target'-block and 'Run FPGA'-block work without any error code. The configured pathway in the 'Open FPGA' is correct. I submit the VIs.
Any ideas are greatly appreciated!
Regards
Rickard
(3,691 Views)
Accepted by topic author Rickard1
Never mind, I got a later version of labview installed on the computer, and now it suddenly works!
Is there any list from NI of all the labview error codes?
(3,627 Views)
Hi Rickard
You can find explanations for most error codes by going to "Explain Error" under the help menu in LabVIEW.
Best Regards
David
NISW
(3,600 Views)
