Extra data from Agilent N99XX Series Analyzer PnP Driver
I'm having an odd issue with the "Read NA Trace Data.vi" inside this part of the Plug-and-Play driver set.
For whatever reasons, this function is pulling two "sets" of data points, every time I call the function.   So in my application space, I'm doing a 401-point data dump.....but this function returns 802 data points (Capture.PNG).
Any thoughts?   I did not write this VI, used it as-is straight off the NI website.    Thanks,
(3,046 Views)
Accepted by topic author SparkyOne
Agilent devices like to output X-Y pairs.  So you are likely getting the frequency and the amplitude.  Use decimate 1D Array to get the two arrays.
(3,030 Views)
I’m sorry, nevermind.     This is what happens when trying to rush solutions.
You are correct.   -facepalm-    So sorry
(3,027 Views)
