Event structure with true value change
In my code I have value change event for three buttons which executes even though button is ON or OFF i.e.. Value change event. I want to change that option to true event i.e.. When ever button glows then only event should arise. How can I do that?
(3,001 Views)
Hi
You can change the mechanical action of the buttons.
right click on the button on the frontpanel and select one of the latch mechanical actions.
greetings from the Netherlands
(2,988 Views)
