Eurotherm 3500 control using Labview
I need some help regarding the Eurotherm 3500 series communication, I am using 3500 series for controlling a fan and a feedback from a mass-flow sensor, with labview on a computer, how should I set it up?
1-is my fan (Modbus RTU, EIA 485) a slave 1? massflow sensor (Modbus RTU, EIA 485) slave 2?
2-how is the wiring for them?Just link the two slaves together to Eurotherm 3500 HA to HF? and JA to JF is for the LabVIEW computer?
or use one 3 units of 3500 series 1 for master and 2 for slaves?how is the wiring then?
It would be better if someone can put on a wiring schematic here and the setup as I am completely new to this as a mechanical student.
Thanks for your kindest help.
(3,034 Views)
Since this is apparently a class problem that your professor gave to students to do, I think it is best that you do your own work instead of submitting someone else's work as your own. The latter is cheating.
or
If this is something required by your employer, I would like to paid for doing the work. 😉
(2,968 Views)
