Error with Tcl GPIB commands when passing arguments in a procedure call
If I were to simply make a call to a power supply such as:
gpib open -address 5
gpib write -message {VOLT 20}
my power supply would set the voltage to 20VDC
However if I were to make a procedure that sets the voltage and pass the voltage value as an argument - then the Agilent instrument gives me an Invalid Character response (code -101).
example:
proc SetDCPower {gpibID DCPower} {
 gpib open -address $gpibID
 gpib write -message  {VOLT $DCPower}
 gpib close
followed by a call to this procedure with the following in the same TCL script
SetDCPower 5 15
Other commands such as gpib write -message {POW ON} work fine in a procedure so I know the GPIB address argument works.
I have also output the DCPower argument to the screen and text file - and it looks normal.
Anyone have this issue?
Message 1 of 8
(5,149 Views)
OK. It looks as though the GPIB command will not accept a variable in place of a number regardless of whether it is an argument from a procedure.
I defined a variable:  set ThisIsATest 15
the made a call with it in the same procedure:  gpib write -message  {VOLT $ThisIsATest} and it still fails.
Thus my question is now - can a TCL GPIB command be given with a variable in the SCPI message
Message 2 of 8
(5,147 Views)
Krusty,
Because youre using a third party language to interface with an Agilent power supply, you may have more luck asking this on the TCL developer's site here:
http://www.tcl.tk/community/
Theyre most likely going to have a much more in depth knowledge for how to program and troubleshoot in TCL.
Kyle Mozdzyn
Applications Engineering
Kyle M.
Message 3 of 8
(5,138 Views)
Yes I agree, and I have actually posted on one of the services from that web page. However, there were some TCL related questions on this discussion board and thought I would see if anyone else had similar experiences.
Message 4 of 8
(5,136 Views)
I figured out what the problem was. It had to do with creating a string using the variable prior to sending the command.
Message 5 of 8
(5,132 Views)
Hi Krusty,
I am happy that you were able to figure it out!! Excellent!! Smiley Happy
Perry S.
Message 6 of 8
(5,121 Views)
I know this is an old post, but I was wondering if you could help me.  I ran into virtually the same problem and its had me stumped. I was wondering if you remember how you fixed this.  If so, could you share the code?
Much Appreciation,
CAO
Message 7 of 8
(4,967 Views)
Have you also posted your questions to the other forum listed for the third party code?
As stated above:
Ian M.
Message 8 of 8
(4,948 Views)
