Error Code 1073807202
While using the VISA read or VISA write option, i am getting the error code 1073807202 which says code library not found. Where can i find the code library? What should be done to rectify this error?
(4,071 Views)
When this error happens, the cause is usually that NI-VISA itself is not installed. Install it from the drivers CD or download it from https://www.ni.com/en/support/downloads/drivers/download.ni-visa.html. Did you search the forum for that error code? It's a common problem and should be easy to find.
(4,061 Views)
I was looking for a link to download these drivers. Thanks a ton!
(4,043 Views)
