‎09-05-2006 04:32 AM
Hi
I have updated the version of the CMU200 to V4.2 I have also updated the cmu-k53 BT option to V4.2 as well I used the links you sent me yesterday.
My lab view drivers were downloaded today from your website Still a lot of errors Help needed ASAP For your convenientI am working with Lab view 7.1 And I attached the .llb for you to run it yourself Thanks Shai
Error -1074001656 occurred at RSCMUBT_Init_BT_Sig.vi
This error code is undefined. No one has provided a description for this code, or you might have wired a number that is not an error code to the error code input.
‎09-05-2006 08:04 AM
You should really have posted back to the <A href="http://forums.ni.com/ni/board/message?board.id=170&message.id=203922#M203922">thread</A you had already started. And, as I mentioned there, the driver is downloaded from R&S and it has been written by them. Since that error code is undefined and the LabVIEW driver is really a CVI driver, you have no LabVIEW source code to look at. My only suggestion is to contact R&S to see if someone there can explain the error. Can you get any functions in the driver to work?
‎09-05-2006 01:27 PM
‎09-06-2006 07:10 AM
‎09-07-2006
04:04 PM
- last edited on
‎05-26-2025
04:48 PM
by
Content Cleaner
Is this the same issue you posted here as well? Have you tried Albert's suggestions?
I would make sure you have the latest VISA driver from National Instruments. Since NI doesn't support or maintain that driver, you might want to contact R&S to see if they have seen this type of issue with the driver they developed.
Best Regards,
Adam Wooderson
