Error -1073807360 occurred at Property Node (are 8) in VISA Configure Serial Port (Instr).vi->practise.vi
hi,
    I want to write data from labview to my micro controller(PIC18F87J50),but i am getting the above mentioned error,here i will attach my labview code and mcu code ,please go through them and help me with a solution
(4,625 Views)
The only glaring thing I see is that you only need to configure the port once.  So do that before you loop.  You should also close your port after the loop.
GCentral
(4,609 Views)
This normally indicates a property node that cannot have that value.
I don't see the values you use in the vi front panel.
Maybe a wrong baudrate or some other value that is not accepted by your serial port?
greetings from the Netherlands
(4,578 Views)
