Error -1073807346
Good day all.
I have a net work analyser N9925A. I had downloaded the relevant driver and I was exploring the examples given. However whenever I run the .vi program, there will be an error message prompting me as shown in the attached image.
Is there someone have an idea to help me to fix this probleme?
(2,195 Views)
You are not giving a proper reference to the device.  We would need to see some code to give any better advice.
(2,164 Views)
 Please can you explain for me with details .I'm not understand you.
(2,142 Views)
How are you telling the driver what device it is trying to talk to?  That is somehow wrong.  Again, we need to see code and more details on the device (ex GPIB or Ethernet address) in order to give more details.
(2,136 Views)
Fine thanks,
    I have installed Labview 2018 in my PC (OS: Windows 10) . After that I installed VISA 18 and driver for labview of VNA N99XX.
I want control a VNA N9925A  with Labview via serial USB connection, but in Max i can't detect this VNA and when i applay an
exmple.vi i have the error -1073807346.
   Please how i can tell to the driver what device it is trying to talk to?
(2,119 Views)
That is your problem then.  There might be a setting in the VNA to allow USB communication or you might possibly need to install a driver.
(2,111 Views)
  I verifey there's no setting in the VNA and i instal the driver for labview of the VNA with VISA18 but
always i have the same probleme. i don't know is there another software to instal it ?
(2,091 Views)
