Error -1073807302 only in one program
Hi to all
When i run "HT.vi" to talk with a serial device, it works without errors, but when i run "Prueba QSM.vi" to talk with the same serial device, using the same hardware (a USB-Serial Converter Trendnet TU-S9) I get Error -1073807302 only when the device sends the first line "\00Serial Device\sOnline:". I can turn on n times the device and I get n Errors. How can I avoid it?
(3,282 Views)
(3,256 Views)
