ENC28J60
Has anyone communicated with the ENC28J60 board?  I am using it in a relay board and through ethernet want to control it.
(3,648 Views)
It sounds like you want to communicate with this chip via Ethernet and therefore you should have no problems doing this by sending Ethernet packets via either UDp or TCP/IP Commands.  Howeever which particular commands you will have to send will be particular to the ENC28J60 microchip and thereforeyou will have to get a hold of the Programmer's guide for that chip.
I unfortunately have not had the chance to try to communicate with this board directly.
If you are having specific problems with communicating with thechip post back with specific questiosn and we will try to help you
Thank you
Charley Dahan
Global Account Manager
(3,616 Views)
Thankyou.  Let me look into the programmers guide.
(3,604 Views)
