E4418B Serial command
Now I can control my E4418B with some commands
the commands are "*IDE?", "*RST", "*TST",
but I cannot use "MEAS1?" and some else
what is problem?
And,, I can make remote mode with scpi command mode
but HP437B doesnt work..
Helpme T,T
(1,684 Views)
Post the code you are using.  Without seeing that its hard to guess.
(1,623 Views)
Thank you for reply about this humble one..
I forgot post my code but I solve the problem!
The problem was I was using HP command mode with sending SCPI command data!
Thank you!
(1,620 Views)
