E-515
im supposed to get a piezosensor to oscilate with at least 10 Hz but the
"set value" is to slow. do anyone know how to get it faster??
(3,637 Views)
Hi Ola
Are you using an instrument driver to change the frequency? 10 Hz should be doable uless the driver puts an upper limit on the maxmimum allowable value. If that is the case, you can always change it in the driver and maybe the amplifier or other unit driving the piezo-element.
Ram
(3,637 Views)
