Dual directional coupler
Hellow!
Anyone have the idea about dual directional coupler? what does it use for? can i use it on a high voltage source? thanks!
Message Edited by happybird on 07-06-2005 10:31 AM
(3,555 Views)
DDC's are used to sample incident and refelcted power without disturbing the charactereistics of a transmission line. Can be used for line monitoring and power measurements usually in the GHz range.
What application did you have in mind regarding high voltage? I doubt this is what you need, but then I do not know the application either.
Wingdings?
(3,531 Views)
Hellow!
are there any dual directional coupler which operate in low frequency(100Mhz-200Mhz),is it possible to make one? thanks!
(3,506 Views)
Well, the 2nd Google hit out of 100's found this one, 100MHz-2GHz range
http://www.home.agilent.com/USeng/nav/-12173.536879998/pd.html
Unless you are expereinced at high frequency design and layout, I would suggest purchasing one rather than building
(3,503 Views)
Thanks for you searching,i think it is too expensive for us,i found another one:
Do you think they are the same thing? will it work for us?
(3,497 Views)
