07-04-2007 06:58 AM
07-04-2007 07:48 AM
According to the download page, the driver supports a serial connection. You have to use the correct cable, set the com port on the scope to the settings mentioned on the Initialize VI, and select the com port in the VISA Session control.
Are you sure you downloaded the correct driver? There is a 8.0 project style, 8.0 plug & play, and a 7.0 plug and play. the 7.0 version is available at https://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E3B19B3E9139659CE034080020E74....
