Drive ethernet power supply from cRIO-9045
Hello all,
I would like to control a power supply (EA-PSI 91500-30) with my cRIO-9045 but I can't add a network device on iMAX I have this message :
After, I tested directly with NI veristand and Instrument addon with TCP mode and the IP address of the power supply but nothing works.
Do you have any advice for me?
Thank you in advance for your response.
(1,197 Views)
Hi Mahmoud63PPC,
I had the same issue creating a Network visa resource. See the solution below.
https://forums.ni.com/t5/Instrument-Control-GPIB-Serial/cRio-9045-VISA-Network-Resource-Creation/m-p...
(1,153 Views)
