The PCI-485 uses standard 16550 UARTs, and while there isn't a packaged DOS driver avilable, you should be able to use the card in DOS applications by configuring the software to use the base address assigned to the UART that you wish to use. One important note is the RS-485 wire modes which are configured via the scratch register. The user manual documents how this is performed.
