Does anyone have experience with Signatec High-Speed Digitizers?
 I just purchased the PX14400 and I have a few questions for anyone that may have some experience with these.
(3,660 Views)
Hi ryder_2010,
What specific questions do you have regarding this device? Is it relating to it's actual application or do you have questions on how to operate it using LabVIEW?
Raj
(3,634 Views)
I am trying to set up software for a time of flight mass spectrometer which uses the new digitizer and labview and was looking for someone that has done anything similar to that.
(3,628 Views)
Hello ryder,
In order to communicate with your device in LabVIEW you will need to be able to call into the driver provided with the device. There are a couple of ways you can go about doing this:
1. You can call into the dll from the driver in LabVIEW (https://forums.ni.com/t5/Developer-Center-Resources/Calling-C-C-DLLs-from-LabVIEW/ta-p/3522488)
2. You can create your own driver using the VISA Driver Development Wizard
3. If your device came with software you can have it save a file and then manipulate the file in LabVIEW
Let us know if this helps out
Best Regards,
Adam G
(3,600 Views)
