Data transfer
Using a Tektronix TDS7000 series scope, I want to transfer scope data in .CSV or .TXT out from the scope into an external PC via GPIB.
From the scope the acquired data has an accuracy of 5 decimal points.
I want to know, when I transfer this data using an NI GPIB card connecting my PC and the Scope. Will I see a truncation/rounding off of accuracy? say from 5 dp to 3dp?
(3,912 Views)
GPIB does not truncate any data. GPIB is a byte-parallel bus that transfers one byte at a time from the talker to the listener. The data that the device sends will be exactly the same data that the controller receives.
(3,912 Views)
I'm trying to transfer a waveform from a TDS7000 series scope in a .csv file.  I have a TDS7704B and I can save the image file as a JPEG but not the waveform as a .csv file. Here is my string inputs to NI VISA:
DATA:SOURCE CH1
SAVE:WAVEFORM:FILEFORMAT SPREADSHEETCSV
SAVE:WAVEFORM CH1 (DESTINATION AND FILE NAME)
EXPORT START
Have you get this working and will you share the code?
(3,436 Views)
(3,433 Views)
