Hi Stan,
You are correct; there is a 100 character limit in the "Send String"
window. The Communicator is meant to be used to test out
configuration settings. It is not meant to be used in production
or for more robust applications. These applications are generally
written in a certain development environment (LabVIEW, CVI, .NET, etc.)
and will allow you to send larger strings over GPIB. Are you a
development environment to program your application? What is your
overall goal with this setup?
Robert Mortensen
Software Engineer
