Data Acquisition with Agilent U2356A
I am a first time user of Labview and am trying to write a program to utilize an Agilent U2356A multifunction DAQ.  I can't find a specific Labview driver for this model so I am using an IVI driver.
At this point I've been able to initialize the unit and configure the channels I want to scan, but I am having trouble reading the data from the unit.
Any help at this point will be greatly appreciated.   I have attached the base of which I am working with.
Thanks again,
Jason
Message 1 of 11
(5,687 Views)
Jason,
I have been playing around with this for awhile and also reading through the U2356A Help and Examples.  Agilent provides a C# example that does an aquisition, and I have tried to translate that VI into LabVIEW.  Since I don't have an Agilent DAQ, I cannot test this out in any way, so no guarantees.
Ben
Certified LabVIEW Associate Developer
Certified TestStand Developer
Message 2 of 11
(5,667 Views)
Ben,
Thank you for the response but unfortunately I can't open the file.  I am currently using version 8.5 which won't allow me to open your file.  Would it be possible to re-save the file?
Thank you again.
Jason
Message 3 of 11
(5,659 Views)
VI saved for LabVIEW 8.5
Ben
Message 4 of 11
(5,657 Views)
Ben,
Thanks but when opening the new file I again receive the message:
"LabVIEW load error code 9:  VI version (8.6) is newer than LabVIEW version (8.5)."
Sorry to be an inconvenience.
Jason
Message 5 of 11
(5,652 Views)
It's no inconvience.  I must have posted the same VI again.  Try this.
Ben
Message 6 of 11
(5,648 Views)
A certified LabVIEW driver for Agilent U2300 Series will most likely be available in Q1 2009 on IDNet.
Message 7 of 11
(5,624 Views)
Any update on when this might be available?
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
Message 8 of 11
(5,359 Views)
The driver might be finished by the end of March. Please check again in mid-March. Thanks!
Message 9 of 11
(5,330 Views)
Any word on the driver for the Agilent U2356A?  I'm purchasing this unit, and I need a driver quick!  Thanks a lot..
Message 10 of 11
(5,179 Views)
