DLL linker Labview
I have a question about DLL link,
Agilent has a software for Excel or Word automation,
this software can downlown from Agilent web side,
and software name is "IntuiLink 4395A/4396B/4294A Automation",
I want to use LabVIEW link "AgtServer4395.dll"  of one`s files,
this software has document help as below,
-->Returns a bitmap image of what is currently displayed on the instrument's display screen.
-->Syntax
-->Object.GetScreenImage[(varScreenImage )]
-->Data Type
-->Picture
-->Settings
-->formatAs Agt_ImageFormatdefines the format for the image.The format can be set to BMP,GIF,TIF,JPG,WMF or EMF.
-->Description
-->Returns an image (bitmap)of the instrument's front-panel.
-->Technical Note
-->Differences in the rendering engines will cause a noticeable difference in the appearance and placement of text.Differences in rounding ---->algorithms may cause verysmalldifferences in the appearance of waveforms against the graticule.
-->Remarks
-->キ You can use the GetScreenImage method to insert the screen image in a control (such as Image or PictureBox)or you can save the screen image in a variable declared as a Picture.
-->キ This method extends the timeout value in effect to allow for execution and then restores the timeout value to the one set by the Timeoutproperty.
-->キ This code inserts the screen image in an image control.
-->キ Set Image1.Picture =Server1.GetScreenImage
-->キ This code will set the variable screenShotto the screen image and then insert it in an Image control.
-->Dim screenShot As Picture
-->Set screenShot =Server1.GetScreenImage
-->Set Image1.Picture =screenShot
but I still can not used this  "AgtServer4395.dll"  to link to LabVIEW,
I want to use GateImage Function,
So, Could you Help me check this DLL file ?
Best Regards,
Angus
由 AngusCheng 在 06-07-2008 02:41 AM 上編輯的訊息
由 AngusCheng 在 06-07-2008 02:44 AM 上編輯的訊息
由 AngusCheng 在 06-07-2008 02:45 AM 上編輯的訊息
(5,820 Views)
Hello.
看起來是 Visual Basic 的DLL.
您必須要使用 Active container & property node & invoke node.
(5,770 Views)
我使用ActiveX 的 Container 去連結可是只能控制一些初始設通訊的設定
除了使用ActiveX的方法,不能使用其他的方式去連結了嗎?
麻煩你在幫我看一下
這是Aglient所提供的資訊,
Recommended for:
キ Visual Basic
キ Visual C++
Name: AGTSERVER4395 Automation Server
Description: AgtServer4395Lib
File Name: AgtServer4395.DLL
Agilent 4294A, 4395A, and 4396B Impedance Analyzers IntuiLink Version 1.0,
(5,754 Views)
不好意思,
我可以連結了
我用錯方法.......謝謝你的Sample code
(5,751 Views)
Next time you can post to ni.com/taiwan/forum.
NI Taiwan AEs
(5,747 Views)
Link off.
(4,090 Views)
