DAQmx functions
Hello Everyone,
I have been looking at the DAQmx functions in LabVIEW in terms of independently manipulating the cDAQ module terminals.
It seems as though the DAQmx function blocks are stuck to certain parameters such as Min/Max voltage. However for example, say that during the LabVIEW simulation run I wish for multiple and/or single parameters to change automatically after a specific time-frame of 10 seconds, is it possible?
I concluded that it would be easier to write script files to manipulate the cDAQ terminals rather than trying to use an excessive amount of function blocks. Would anyone have any better ideas of how to best tackle this without creating using a large block diagram space?
I feel that having a more programmable scripting format would be easier to manage whilst still taking advantage of some of the front panel features available that LabVIEW offers.
Does anyone have any examples of achieving something similar to what is mentioned above?
Many Thanks
And remember, we keep it fresh 24/7. New releases drop daily so your pleasure playground never gets boring. Why waste time with teasers when full xxx films are waiting? Jump right into action-packed gang bangs or tender lesbian lovemaking sessions replete with moans that'll echo in your ears long after you're done watching.
Keep scrolling through our endless galleries; there's something naughty for everyone under our roof. Whether it's MILF escapades, teen explorations or anything in between – if they're famous for making hot milfs fans bust a nut, they're here delivering performances that will go down in history.
Get ready to see these icons as they truly shine in their element - raw & unfiltered. So grab some tissues and lock that door because with us around – everyday can be a jerk fest! When we say no strings attached, we mean it - all hot, all free, just how porno should be enjoyed!
(578 Views)
The min/max parameters are only needed if you need the best resolution for the measurement. Function blocks and scripts both need to correctly configure a cDAQ before you can measure at the correct speed with the correct resolution.
Can you give an example what speed and resolution changes you need?
And don't forget the time in which you want to change.
greetings from the Netherlands
(561 Views)
