Controlling a SainSmart USB relay from LabView?
Korpz,
I just used the VIs Mercedes included in their attachment.
Will
Will
CLA, CLED, CTD, CPI
LabVIEW Champion
Choose Movement Consulting
choose-mc.com
Message 11 of 15
(1,582 Views)
Here is a simple driver for the 16 ch USB Relay Module from SainSmart.
It is in a Labview 2018 vi.
If you have any questions, feel free to contact me
Message 12 of 15
(906 Views)
Here is the same code from above exported to run in LabView version 8 or newer.
Message 13 of 15
(882 Views)
Is there a .vi that works with the 4 relay or the 8 relay boards?  The 8 relay board is especially problematic.
Message 14 of 15
(380 Views)
Here,
I modified the 16 Relay code some to allow for different relay options and tried to clean-up the unit response handling as well.
See if this works.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
Message 15 of 15
(281 Views)
