Controlling Custom Instrument over Ethernet
I'm trying to setup the communication for a custom made instrument programmed in LabVIEW.  I would like my instrument to communcate with a PC over VISA like I do with my typical COTS equipment.
Does anyone know a good standard way I can set this up?  The way agilent or a real company does?
I tried using VISA VIs in the instruments code, but I could never get a command from the instrument to the PC.  Not sure if that's even possible since the PC isn't set up as a resource in MAX.  I just used the know IP address and port and hoped it would work.
I also tried using the TCP VIs which did work, but the commands send between the instrument and PC have a lot of time between them.  I didn't know if leaving a TCP connection open would work.  Seemed like it would just timeout after x amount of time (1min?).
(4,748 Views)
I don't understand what you mean by a custom instrument. You mention including VISA VIs in the instrument and the pc is not a resource. That sounds like you don't have an instrument but a pc. Custom instruments are not programmed in LabVIEW.
Instruments from Agilent, etc., have firmware that implement the VXI11 or LXI standard.
(4,744 Views)
The instrument is made in-house and uses an NI touch panel to run a LabVIEW .exe program.  The touch panel is used interface to the user via the touch panel display or remotely through a PC.  I'm just trying to have it talk to the PC in a similar way as a typical instrument does, so it's easy to use.
But really, you're correct the touch panel is a PC that is running XP embedded.
(Also I'm not too familiar with TCP/general comm protocol, so feel free to state the what seems like the obvious because I am learning as I go with this.)
Thanks for the reply!
(4,729 Views)
I would just treat it as 2 different pc's connected via an Ethernet cable and use the TCP/IP functions. On both, you would have a VI that both sends and receives messages. You would have to design your own message protocol - a command followed by data for example.
VISA also could be used I think. Did you try going into MAX and adding a TCP/IP resource? This has to be done manually.
(4,725 Views)
I recommend using the Simple Messaging Reference Library.  It is a really good library for simple communication between two computers.  I have used it for several projects.  It is also available on the LabVIEW Tools Network and VIPM.
(4,714 Views)
