Control variables server and client
Hi Good day.
I have a doubt as to have control from two PC running labview 2011 with the tools  TCP / IP using the port RJ-45.
We Perform Both Communication And Can be controlled from server to client, but I have not found a way to do it vice-versa, from client to server.
Thanks.
(3,903 Views)
You use the same TCP/IP Write and Read regardless of who the "client" and "server" are.  Use the TCP/IP Write to send the data to the client/server and use the TCP/IP Read to get the data at the client/server.
(3,897 Views)
hi thanks for the reply.
I've tried to do that, but when starting the program again it stops working and I have to close labview from the task manager that is not responding, this in the same pc but I had the same problem when putting on 2 different pc running the same edition labview
(3,861 Views)
Hello Navidadalfred,
Thanks for posting at NI forums! Could you give us more information about the program? The program hangs before you run it, or in a certain point of your code while executing? What operating system are the computers running?
Best Regards,
Alina M
(3,819 Views)
