Control Solenoid Valve - interface
I want to control 5 solenoid valves through LABVIEW programming. Which interface I should use to communicate to Labview?
The solenoid valve datasheet:
https://www.kleen-ritecorp.com/p-62064-mac-valves-35-series-direct-solenoid-3-way-poppet-valve-1-8-i...
Shreya
(2,841 Views)
You should have a DAQ device before jumping to LabVIEW.
(2,367 Views)
