Control RS232 equipment through WiFi
Hello
I need to develop an application to remotely control an equipment with RS232 communication port.
The idea is connect a WiFi to serial adapter (http://www.usconverters.com/serial-rs232-wi-fi-adapter) to the equipment and access to it through WiFi network.
According to adapter's manufacturer (U.S. Converters), the adapter has a software utility which creates a virtual COM port in Windows. The virtual COM port can then be used almost as if it was a regular native serial COM port.
Can I use LabView to access to this virtual COM? How can I make it? Or someone have another solution that I can use.
Thanks in advance for your help.
(1,533 Views)
If the Wifi-Serial adapter can show up as a COM port, you should be able to select that port from the VISA resources control and use it as a regular serial device and all other translation over WiFi be taken care of by the manufacturer's driver
Santhosh
Soliton Technologies
(1,468 Views)
Hello
Thanks you Santhosh for your help.
(1,456 Views)
