Control HVA converter with ni 9263
@santo_13
The pin6 of HVA is signal ground,which is connected to the COM of NI-9263
Message 11 of 15
(667 Views)
In 9263, each AO channel is isolated, so you need to connect each channels' COM to HVA's GND.
Santhosh
Soliton Technologies
Message 12 of 15
(656 Views)
@santo_13
In fact, I have tested and connected all the AO COMs of NI-9263 to pin6 of the HV converter, and the feedback voltage from pin4 is still 0
Message 13 of 15
(643 Views)
When connected to the HVA amp, were you able to ensure the AO output voltage is correct? sometimes if HVA is too much of a load, the voltage might be clamped.
Santhosh
Message 14 of 15
(636 Views)
I have tested the voltage of each pin relative to pin6 with a voltmeter, and they are all correct, except the HVA output.
The test result is as below:
Message 15 of 15
(612 Views)
