 kaush
			kaush
			08-31-2010 04:25 AM
I am using Comsoft DF_PROFI2 with P&F Coupler to connect PA device. I am not able to configure the PA device in the configurator. I am getting "Station not Existent". Please help to resolve this issue.
 S._Fischer
			S._Fischer
			08-31-2010 05:04 AM
Dear kaush,
please try to use the busparameter settings from following side: http://www.profibus.felser.ch/index.html?dppa_segmentkoppler.htm
Try to create a livelist after switching to online mode.
regards,
Sven
08-31-2010 05:34 AM
Hello Sven,
Thanks for the reply. I am not to change the master bus parameters. Please see the attached screenshot.
 S._Fischer
			S._Fischer
			08-31-2010 06:20 AM
Hello Kaush,
please select in the tab "Profibus" the Profile "user defined". Then you are able to set the bus parameters.
Sven
09-02-2010 03:52 AM
Hello Sven,
I am able to get my PA device online and see the parameters. I want to know how to get the data into labview. Is there any example or document which i can refer. I am using LV 2009.
		09-02-2010
		11:51 PM
 - last edited on
		02-19-2025
		07:08 PM
 by
		 Content Cleaner
			Content Cleaner
Hello Kaush,
This link would give you a complete overview of the Modbus Library for LabVIEW - https://forums.ni.com/t5/Reference-Design-Content/LabVIEW-Modbus-API/ta-p/3524019
There is a tutorial on using the Modbus library as well as a demo on creating an I/O server with the DSC module.
Regards
arjun
 MoahmmadFayiz
			MoahmmadFayiz
			08-22-2023 02:00 AM
thank you Arjun,
this was great, and solved my issue.
